need to burn DVD to send to USA
brayspeed
Post by brayspeed »
Have made a film and burned it in pal format and it works fine but have been asked to send one to the USA, I know they use the NTSC format so if i simply change the settings and re burn one in that format will i be OK
Please Help
Tony
heinz-oz
Post by heinz-oz »
Never done this but should be possible. It'll be a lengthy encoding process since the frame size and rate are different. I also believe there are specialised converters available.
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
Depends on the quality you want. If it's family and they don't expect too much you could import the pal version into an ntsc project and work your way through.
If you want to do it properly you need a proper standards converter, as it's not just frame size adn frame rate that differ, but also the way the luminace/chrominace is delivered. Look at Canopus Procoder.
