Anyone found a way to multitrim video with transistions?
keithm
Post by keithm »
Anyone found a way to multitrim a video then add transitions between the sections? You can edit bits out of a video but when you click ok it shows as one complete video and so you would have to add the transitions manually (no hope at all if the adverts have been removed). You can choose add transitions automatically but it does that by scene change.
Surely there must be a way to multitrim a video then add transitions between the cuts?
ploggy
Post by ploggy »
depending on the content of your video (fast scene changes, etc), you can automatically add transition to the cut portion.
here's what I did:
Multitrimmed a 00:01:06 video into 3 segments with 10 seconds each. (see below)
http://www.geocities.com/ploggyboy/scre ... titrim.jpg
After multitrimmin the video I went to Enhance video and clicked on the Auto Add Effects. (see below)
http://www.geocities.com/ploggyboy/scre ... sition.jpg
you will see the transition effects are added in the join section of the 10 sec segments.
Who? Me?
keithm
Post by keithm »
Thanks for the response. I did try the auto fx but it was taking forever on a one hour video: I suspected it was detecting other scene changes aswell as the cuts: you would think you could just add the transistions to the cut points.
