photos
- VikingAnimations
- processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
- ram: 4 GB
- Hard_Drive_Capacity: 1 TB
- Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Use the circular selection tool. Once you've selected the area you want, click the selection options button, and select Inverse. Click it again and select "Make selection area transparent."
If you click the link to my site at the bottom of this post, you'll find a tutorial or two on GIF Animator 5 that should answer most of your questions.
angle smith
VikingAnimations wrote:Use the circular selection tool. Once you've selected the area you want, click the selection options button, and select Inverse. Click it again and select "Make selection area transparent."
thank you so much i was also wondering how to add premade glitter to a section
- VikingAnimations
- ram: 4 GB
Check out this tutorial - this will give you a hint...
http://animationstation.fateback.com/tu ... intext.htm
If you have premade glitter, you may need to duplicate it and move it to make the area big enough.
