Why is DMF 4 reencoding Video Files - Solved!
bt1968
Post by bt1968 »
I am bringing in DVD compliant mpeg files
Mpeg-2 Video
24 bits, 720x480
29.97 Frames/Sec
Variable Bit Rate 6400kbps
Audio Type: Dolby Digital Audio
Attributes: 48000 Hz
Bit Rate: 448 kbps
Any idea why it gives me the Converting Video Title when I try to burn.
It seems like my file should be DVD compliant.
I have the check box marked for do not convert MPEG Files. Any ideas?
[/img]
Did you do anything to the files you imported? Such as add a title, split, transitions, audio?
If so then it will need to re-encode them...
bt1968
Post by bt1968 »
Nope - didn't do anything to them other than add them to a menu.
jfkeenan
Post by jfkeenan »
There's a checkbox that says "Do not render validate MPEG..."
Or something like that.
You need to have that checked.
Re: Why is DMF 4 reencoding Video Files
bt1968 wrote:I am bringing in DVD compliant mpeg files
Mpeg-2 Video
24 bits, 720x480
29.97 Frames/Sec
Bit Rate: 448 kbps
[/img]
jfkeenan,
He mentioned that he did have that checked...:)
keithm
Post by keithm »
I think the audio has to be 244 kbs at 48khz
ploggy
Post by ploggy »
just a question... is that video of yours in Dolby 5.1 format?
Who? Me?
bt1968
Post by bt1968 »
Turns out that some of the movies in my project were I-frames only, mpeg-2 format, which for some reason, DVDMF has to re-encode for it to work.
Thanks for the replies.
