Another problem, list now longer than my arm! NO AUDIO!
And Rew
Post by And Rew »
i installed mf4dc and started using, couldnt run extra content cd. but carried on, i wanted to burn my avi files to dvd. 6 files 42min long to be exact. i found that if i exported them using LP 4:3 then the 6 clips would fit to a 4.7 gb dvd GREAT! so i expoted 3 straight away and they worked perfectly 3 more to i thought then i ll have my dvd. then i found i couldnt fit the 6 clips to a menu. so after much searching and questioning on forum i installed the extra content, which was a nightmare i wont go into. i can now have up to twelve clips on menu HOORAY! so lets make my dvd........ NO. trying to export the clips again and there is no sound! i ve tried a few things like changing the properties, even recording one clip straight to disc has no sound. slowly losing will to live, going to sleep now. please someone help me.
i will put properties of clip i m trying to export and one ive alredy exported in the hope someone can tell me what to do, not much hope though.
Clip to EXPORT: AVI file
358,145 KBytes
23.976 Frames/sec
2525.234 seconds
140.28 kbps
DivX 5.2.1 Codec
24 Bits, 608 x 336
60,545 Frames
MPEG Layer3
48.000 kHz, 16 bit, Stereo
121,198,464 samples
clip already eported:
well this now seems to have gone back to original size when i put it in mf4 although it is still taking up double the size on hard drive. thats it i give up........... i m only a simple man :x :shock: :( :( :(
