Ok let me see if I can give you the full rundown and see if anyone can see the problem.
I am using .avi captured video from my camcorder. For photos I am using .jpg's. I have a few music clips that are mp3's. And then some text I added with V9.
My settings for creating a video file are:
MPEG files
24 Bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 16:9
LPCM Audio, 48000 Hz, Stereo
V9 is installed one my system hard drive(8 gigs of space remaining) with all playback and save options on a seperate hard drive(75 gigs remaining).
I found this on the Ulead site and did exactly as instructed:
System Tweaks
Tweaking your system for video editing
* The following are useful, video-specific tweaks for improving the performance of your system. Some of the paths may vary slightly between various versions of Windows.
* If you have two hard drives on your system, install the software on your system drive (usually C: ) and capture video to your other drive (usually D: ).
* Your display card shouldn't use too much of your resources just to provide you with overlay. Right-click on your desktop, select Properties>Settings. Lower your color depth to "High Color (16-bit)", and set your screen resolution to 1024x768. You might want to disable some of the high-end 3D gaming features, which have no bearing on video display.
* Make sure DMA is enabled: Select Control Panel, System>Device Manager. Select IDE Controller>Primary/ Secondary>Advanced, and make sure DMA is selected on each of your drives.
* Disable "Write-Behind Caching" on the hard drive used for video capture. Go Control Panel>System, right click on your hard drive, select Properties, and make sure Write Caching is DISabled.
* Change the values of your Paging File (Swap File) size in Control Panel>System> Advanced>Virtual Memory. Set the minimum and maximum values to twice your amount of RAM. So if you have 256Mb of RAM, set both your minimum and maximum paging file limits to 512.
(found at
http://www.ulead.com/learning/general/video_02_1.htm)
The video I am trying to make runs about 41 minutes and has some transitions and effects.
My system is a pentium 4 HP with 1.5 GHz...512 SDRAM memory...nVidiaTNT2 M64 graphics card with 32 MB SDRAM.
I have disabled all allowed software when attempting to create. Does anyone see anything here that might be causing this problem?
One other thing, I tried the Intervideo WinDVDCreator and made a small clip. It saved just fine. The same clip in V9 freezes up my comp. I would prefer V9 because the filters and effects are much better but I don't understand why it won't work and the other one will.
I also go to task manager and change the V9 setting to high priority.
Any ideas?
