matrox rtx100
markfok
matrox rtx100
Post by markfok »
hi,
i used matrox rtx00 with adobe premiere pro1.5. i'm not so happy with adobe ppro 1.5 as i've to baby sitting with my pc when i've several projects to render. does mediastudio pro compatible with matrox rtx100? does batch converting utility exist in msp 8.0?
thnks n rdgs
marc
Terry Stetler
Post by Terry Stetler »
I too have an RT.X100/PPro and totally sympathize :-P
Matrox is the one who would have to provide a set of MSPro compatable drivers, and they won't be doing so. The reasons come down to this;
1. the RT.X100 development team is very Premiere oriented. As far as they're concerned other editors don't exist.
2. the RT.X100 is nearing the end of its life cycle. At most I see 1-2 more driver builds before it's retired. As such developing drivers for another platform isn't economically viable.
3. its replacement product, the AXIO, is already out and costs anywhere from $7,500 (SD version) to $11,500 (HD version) USD. Guess where the bux are?
BTW: this info is solid. I'm a former RT.X100 beta.
That said this is what you can do with MSPro 7/8 and the RT.X100;
1. use its IEEE-1394 for DV capture/export
2. use its analog capture drivers for acquiring RGB, YUV or analog DV/DVCAM footage. This requires also having PPro installed along with the RT.X100 drivers so the Video for Windows drivers are active.
3. use the *.tga's it uses for its Organic Wipes in the MSPro MASK transition or in the Pixelan SpiceMaster plugin.
Terry Stetler
