Now that I have created the little red bar that only plays between the beginning and the end of the little red bar bar how do I remove it so it plays the whole project??
Magistrum
Preview remove
Magistrum
Preview remove
Again this appears to be too hard to answer, do you guys actually use the product or just talk about using it?
The little red bar has been set by you.
When you were in ‘Project’ playback you dragged the ‘Trim Bars’ below the preview screen to set a playback target.
If you had been in clip mode you would have removed frames by using the trim bars.
Click on the word ‘Project’ next to the start button.
Drag the trim bars to the sides.
Next time don’t touch what you don’t understand.
Trevor
Trevor
Magistrum
Re "don't touch what you don't understand":
Back when the red line "happened" to me, I wasn't aware that I'd touched anything. Being a careful worker, I was pretty sure it was some glitch in the program, and came to the forum to find out.
If the "red line" were mentioned in the owner's manual index, one might figure this out more easily. In fact the manual does mention the line in at least one place.
