Problem hearing sound
dhpriest
bimmerbe
No DVD audio on player, OK on computer
I have the exact same problem. DVD plays fine on computer DVD player, no sound when played on regular DVD player. These are VHS tapes captured in MPEG-2, MPEG audio. Any help?
THoff
mpeg audio
As THoff mentioned, mpeg audio is not supported by all NTSC DVD Players.
But check how your audio connections are setup for your DVD Player:
Quote from one of the Ulead Manuals (for MovieFactory)
A DVD Player connected to an amplifier via an audio optical fiber cable may not be able to output sound when playing an NTSC DVD with mpeg audio
George
George
warnold909
Re: mpeg audio
Is there no workaround then for recording? Is there anything that can be done at the point of capture or afterward? It seems silly that you wouldn't be able to play a recorded DVD on a regular player (not counting the whole DVD-R/DVD+R debacle)GeorgeW wrote:As THoff mentioned, mpeg audio is not supported by all NTSC DVD Players.
George
rwindeyer
warnold909
I will try that..thanks.rwindeyer wrote:Only thing I can suggest is to select LPCM as the audio format when you do the DVD burning. It's uncompressed (so takes up more space) but it is universally compatible.
My workaround today was to re-record the disc using a standalone DVD burner....GAH!!!! WHAT A PAIN!
