Hi all. Does anyone know if the new mp4 plugin for MSP8 allows you to create mp4 files correctly for the video ipod? I was considering picking up the plugin if I can find a benefit from it over my current method for storing my videos on my ipod.
Right now I create my video files as .mpg which I later than burn onto dvd for my production. With those .mpg files, I also drop them into this program called Videora which converts them into the ipod format in .mp4 which works out great. It's free software too. What advantages are there to the MSP8 plugin over the free software out there?
MP4 Plugin
sveinan
- motherboard: Asus P8B WS
- processor: Intel Xeon E3-1270 3.40 GHz
- Video Card: AMD Radeon HD 6950 2GB x2
- sound_card: Creative SoundBlaster X-Fi HD SB1240 USB
- Hard_Drive_Capacity: 800GB
- Monitor/Display Make & Model: Eizo FlexScan S2410W
sveinan
Finally got a reply from sales after sending a new reminder of my problem. Got new activation code, that worked without problems. No explanation why the first one didn't work, and no 'we are sorry for your inconvenience'. That is not good customer support as I define it.
First look at MP4 plug-in shows that it only supports Type 1&2. Not Type 10 / AVC / H.264. So don't buy it if you are looking for this.
Over to your question. I guess the answer is Yes&No. Took a quick look at supported MP4 video formats for iPod Video:
The result is then that the MP4 plug-in for Ulead cannot make Type10/H.264. But you probably will be able to make the Type 1 / Simple Profile. I would have to test to be absolutely sure.
Not more time now. Will try to put down a separate post later about feature list of plug-in for others. Since the official material on the web is really lousy. At least ripped me of my dollars. No support for H.264
I guess this tells us that H.264 is the preferred format because of its lower bitrate, but still high quality (I could be wrong, depends on implementation in iPod). But that you can use Type 1 / Simple Profile also. At the cost of larger files.* By following the steps in this tutorial, QuickTime 7 Pro will automatically create an .m4v file containing H.264 video and AAC audio that is optimized for iPod. iPod can play the following video formats:
H.264 video
File formats: .m4v, .mp4 and .mov
Video: Up to 768 Kbps, 320 x 240 pixels, 30 frames per second, Baseline Profile up to Level 1.3
Audio: AAC-LC up to 160 Kbps, 48 KHz, stereo audio
MPEG-4 video
Video: Up to 2.5 Mbps, 480 x 480 pixels, 30 frames per second, Simple Profile
sveinan
@Uryel
No problem understanding that problem. It's a little cryptic navigation as of now. But here is a direct link:
http://www.ulead.com/msp/plugin.htm
alind
same activation code problem
just so people will know, I'm getting the invalid activation code problem too. Also, it's pretty disappointing that they would release this without doing h.264.
sveinan
just FYI: link to post I promised further up about feature list
