Audio filters not recognised by Video Editor
ando775
Post by ando775 »
Thanks, GW.
THoff
Post by THoff »
An easier (and the correct way) to fix such registry problems is to re-register them from a command prompt or the Run dialog:
Code: Select all
REGSVR32 u32cfg.dll
This will re-register all of the COM object interfaces that are implemented in the DLL.
Note that if you have multiple versions of the file, either perform this step from the directory that the file is in, or specify the full path to the file rather than just the file name.
