Import Audio MP3
blade
Import Audio MP3
Post by blade »
I have been getting an error message in video studio 9 about unable to intial the mp3 audio that i want to import from my music folder.
then after that i get the whole video studio 9 crash, and the ms message send report to them....
i know these files have worked before on uvs8 no problems...
anyone have any ideas what might be causing this problem.....
Post by Trevor Andrew »
Quite a few have had this problem with no real solution.
The recommendation to use Wav files seems to work.
If I use MP3’s with a bit rate above 192 kbps I have problems.
192 or below seem to work ok.
Trevor
Also, it seems that certain MP3 versions (e.g. Lame MP3) may cause problems.
San_kev
Post by San_kev »
Same thing happened to me, since last year with V9, since then I transform them to WMA,(almost same size as mp3) rather than WAV (size too big).
And no1 seems to know WHY...
Terry Stetler
Post by Terry Stetler »
Even if you get it imported you may have problems with AV synch/playback due to the way MP3/WMA are compressed vs. the timing of video frames.
Best plan is to convert all audio sources to WAV before using them in a video editor.
Terry Stetler
briancd
Post by briancd »
Generally I copy audio files to my hard drive and convert them to WAV files before inserting them in the timeline. There are a few free audio editors around that you can use. I use Goldwave.
Brian
Photoimpact 11
VideoStudio 9
