ok...want to reproduce this?
here is how it happens to me...
1. Open PI 11 and start a new file...
i chose "Standard > 640 x 350 Pixels" - Custom color background - white
2. select the text tool... type any text...
i chose to type "Thanks a lot"
font: arial, size: 24
3. go back and click the pick tool to get out of text mode and then convert that text to an image.... Object > Convert > From Text/Path to Image
4. now that your text is converted to an editable image, we will use our little friend "quick controls" to change the color and brightness a bit...
10 times on -RED
10 times on +Green
10 times on +Blue
5 times on -bright
5 times on -contrast
go ahead and tap the colors around and change the brightness and color of your text...
5. ok....now that your text is now an image with altered color, lets try to use the keyboard shortcut to "Save As"
hit Ctrl+Shift+S
and BAM, it closes without warning and no saved file....
Thanks a lot
if that doesnt work, try clicking new, and see if u can add text...or just try it again... 9 out of 10 times it closes on me or gives me a fatal error when i start another text project
i dont see how a product that costs $99 made it to the store with all of these bugs... i mean they arent small bugs like typos, they are serious bugs that could cause someone to toss their entire PC out the window because they spent "xx hours" working on a project just to have it close on you when you try to save it...not to mention the post above with a list of known issues...
well, here is one more bug to add to the infestation
