I have PI 6 installed and purchased a physical version of PI 11 UPGRADE and installed it. The install appeared to work fine.
The first time I ran PI 11 a screen cam up with 2 options, don't remember what they were but I chose the second one, then the PI 11 splash screen came up and I could see on the status bar it was doing something for a while. After a while it stopped on "initializing u32lco.fio", it sat there for a while, then the splash screen went away and nothing happened after that. I reboted the computer and the same thing. Tried running the "fix problems" thing on the cd and still no change.
I just did a scan of my HDD and the registry and there is no such file or entry anywhere on my computer. Is there supposed to be?
I also uninstalled the software, removed all other files that were not removed after the uninstall, and reinstalled the sw again, still no luck. Win XP came up with the error report dialogue and I sent that to.
I'm running a P111 1 GB, 758 MB RAM, Win XP SP2, Nvidea GE force 5600 w 256 MB RAM.
PI 11 will not run
ve1trb
ve1trb
no I don't have any software like that.
I followed your instructions after reinstalling the sw and still no luck. It then stopped at u32Bmp.fio, so I removed that file and it then stopped at u32Wmf.fio, so I removed that file and it then stoped at u32Ufo.fio... ( I could go on but I think you see where Im going here).
I also followed the instructions from Ulead to clean up the temp and pi 11 directories prior to reinstalling. Still no luck
The odd thing about this is it seems to go smooth and fast up to the point where it stops loading.
Any other suggestions will be greatly appreciated.
After spending $94.00 Cdn for the software, shipping etc I'd hate like heck to not be able to use the program.
Xyzzy2
- motherboard: MSI Z77MA-G45
- processor: Intel i5-3570K
- ram: 8 GB
- Video Card: MSI R7770-2PMD1GD5 OC
- sound_card: Realtek 892
- Hard_Drive_Capacity: 6.25 TB
- Monitor/Display Make & Model: HP ZR24w
Did it start with all .fio files moved to another directory?
Do you try with Windows Administrator permissions?
Other ideas:
- your anti-virus software interferes
- you may get Filemon tool from www.sysinternals.com and check what's going on when the program loads. You may also get Regmon as well, to check for registry accesses.
Have you tried to contact support (the phone, not the email one)? They probably won't give you any usable solution, but at least they'll know.
X.
Other ideas:
X.
ve1trb
Yes it did start but also failed
Yes
Other ideas:
Completely disabled with all modules shut down
Good idea regarding filemon, I've heard of that before but never really considered it.
I'll have to try that some time, but I'm working with Peter via email at tech support. So far no luck but lots of good ideas.
Will keep posting here until I get a solution, and will pass on whatever works too.
Yes
Other ideas:
ve1trb
Update on my PI 11 installation.
My present status is still no go! At present, I have completely purged everything from my computer that had anything at all to do with Ulead and PI both 6 and 11. I then rebooted and shut down my anti virus, then installed PI 11 by itself and did not associate any files at all to it, as was suggested by another user. All info has been passed to the tech suport at Ulead via email. I have also sent error reports to Microisoft. My PI 11 is still dead in the water.
I suspect tech support is still trying to figure out what the problem is with the software. I'm just glad to see I'm not the only one having this problem, and hopefully they will be able to figure out a solution soon.
ve1trb
