Level Controls
greymann19
Level Controls
In PI 10 I could click on "level" and bring up manual slide bars. Where are they in PI 11?
This is something to do with light leveling.. not leveling a picture to be straight, (which is what I think Zlog is looking for).. I saw nothing in help about leveling a picture. just the light level. I too am looking for this.. I use it alot, especially after I scanned a picture in and the picture was not totally straight on the scanner bed..
I found it, it is still on the Transform tool as it was in the past, only now it is under a icon that lby default states "rotate freely", but if you hit the down arrow next to it, you can change it to "rotate using a horiziontal line", or "rotate using a vertical line.. I guess if I had used the word rotate in Help I would have gotten it.. But to me they are used to put the line against an object that should be straight and then use the bar to straighten it.. ie.. it is a level tool...
