Having trouble with the trial version of Movie Factory
hameed
Post by hameed »
I just installed the trial version of Movie Factory, went to run it (after rebooting ofcourse) and when I try to run it, it says my trial period has expired!
I cannot even try out the software I just installed.
One option is to re-install, but I don't want to have to reboot again.
Any other suggestions to get this resolved?
hameed
Post by hameed »
I just tried to re-install it and I can't even do that, it is asking for some order number.............
DVDDoug
Moderator
Post by DVDDoug »
Once it thinks your trial period has expired, you're screwed. :( It leaves some secret trial behind, so that you can't just re-install every 30 days.
I'm sure there is a "hack" to get around this... but I don't know what it is. I suspect that Ulead won't tell you for fear that you'll spread the secret around. And, I'm not sure but I don't think Ulead support will even respond until you actually buy the software.
The only way that I know of is to back-up, re-format your hard drive, and re-install Windows and all of your applications. Depending on your technical expertese & confidance... this might not be worth the risk! Is that what you meant by "but I don't want to have to reboot again."? "Re-boot" just means to power-down and then re-start.
Or, maybe you can try it out on a another computer if you have access to one. But, then you still won't know if it will work on your computer!
hameed
Post by hameed »
DVDDoug wrote:Once it thinks your trial period has expired, you're screwed. :( It leaves some secret trial behind, so that you can't just re-install every 30 days.
Thanks for the reply! I guess this means I have to uninstall the software.
