Creating Picture CD or DVD
Nikki
Post by Nikki »
Hi Guys
I have created one or two DVD's with videoStudio but I would like to do the same thing with jpg's (pictures) I have no problem adding pics but I want to have groups of picturs and select the groups of picturs like you do when you select a video on a DVD (when there is more then 1 on the same DVD) I want to be able to click on a folder or Icon go view that group of pictures.
Can this be done or should I be looking at another software package
Nikki
jchunter
Post by jchunter »
Nikki,
If you put all the pictures in one long video file, you can build a sub menu in the Burn module that will take you to different "groups" on the file.
Or you can make a separate video file of each picture group and select these separately in the Burn module. You will have a top level menu for each group. You could also build submenus for each group.
John
Nikki
Post by Nikki »
Thanks anyway Guys I got it
You have to save your projects then creat disc
I do have another question is there anyway to change the properties of all the pictures at the same time like the time they display on the tv or do I have to do each one seperatly
Nikki
Post by Trevor Andrew »
Hi Nikki
Change the default duration of new images from File / Preferences / Edit
If you have already inserted your images
Select all image clips in the timeline, using ‘Shift + click’
From ‘Clip’menu at the top, ‘change image colour duration’.
Trevor
