video I/O Error
GIF Animator, SmartSaver Pro, Plugins, Applets....
riverhoop
video I/O Error
Post by riverhoop »
Upon starting Gif Animator i get a error and it boots me out of starting the GIF A. Initial Video I/O any ideas why ???
Bill
bryave
I/O
Post by bryave »
Go to the vio folder under Gif Animator program folder. This is usually C:\Program Files\Ulead Systems\Ulead GIF Animator then delete the uvavi.vio (You’d better to back up the file to some other folder).
†bryave
Harry Sledge
Post by Harry Sledge »
I've been searching all over the net for an answer to this and your solution worked, thank you.
VikingAnimations
processor: AMD A4-6300 APU with Radeon HD Graphics 3-7 GHz
ram: 4 GB
Hard_Drive_Capacity: 1 TB
Corel programs: Ulead GIF Animator 5.05, MotionStudio 3D
Post by VikingAnimations »
Did you miss the sticky at the top of this forum? The answer is right there along with replacement files for the VIO folder that may work for you.
Harry Sledge
I typed "video I/O error" into google and this thread was one of the results.
Do I really need to replace those VOI files because I did what bryave said above and it seems to work ok.
VikingAnimations
ram: 4 GB
Removing the VIO folder means you cannot open any video files. If this is of no consequence to you (i.e. never plan to use GA to open a video file) then then carry on.
However, if at some point you wish to play with video file in GIF Animator, you will need it.
As per the sticked thread, newer versions of those files in the VIO folder have fixed the problem for at least two people that I know of. Hopefully this will work for you, too! :D
Harry Sledge
Ah. In that case I might do what it says in the sticky thread because knowing me I'll want to play with video files at some point.
VikingAnimations
ram: 4 GB
I hope they work for you! Comes in handy now and then... :wink:
Harry Sledge
Yey! It works. Now all I have to do is work out how to use this movie facility thingy.
EDIT: I spoke too soon - if I try to "open video" I get the message: "Unable to find any video file filters" :(
Should I start a new thread on this?
VikingAnimations
ram: 4 GB
Hmm, it would seem that fix of replacing doesn't quite fix it if one wants to open videos.
Back to the old drawing board on that one! :cry:
Well, at least it doesn't crash when loading. Perhaps Ulead will fix that one someday.
Let's try this:
Replace the vio files with your originals.
This time let's try removing one vio file, starting with the uvmpeg1 file, then try GA5. If it still crashes, put the mpeg1 back and remove the uvavi file... Continue until GA works.
Not the fastest way, but it may help nailing this down.
PS If you don't have the originals, let me know, I'll get them to you.
scrumpee
Re: I/O
Post by scrumpee »
bryave wrote:Go to the vio folder under Gif Animator program folder. This is usually C:\Program Files\Ulead Systems\Ulead GIF Animator then delete the uvavi.vio (You’d better to back up the file to some other folder).
Amazing! I have not been able to get Gif Animator to open at all....it keeps asking for a CD for Sonic My DVD!!! I followed this little tip and now it runs properly!
Thank you thank you thank you!
VikingAnimations
ram: 4 GB
It will run, but you can no longer open any AVI files with GIF Animator.
Glad it worked for you!
scrumpee
Post by scrumpee »
VikingAnimations wrote:It will run, but you can no longer open any AVI files with GIF Animator.
Thanks Robert.......guess I'll worry about that when I need to open an AVI file - am waiting for the CD of the software to arrive - would you recommend re-installing the program from the CD?
VikingAnimations
ram: 4 GB
If it works fine otherwise, no. The crash problem is most likely due to a conflict with a codec. If it works now that you removed that uvavi.vio file, then that's the cause. That won't go away until you isolate which codec that is and remove it. Reinstalling GA 5 won't fix that.
For detailed instructions should you wish to get it all going at some point, see GIF Animator 5 crashes when loading Video I/O.
Happy animating!
