I have a dv movie which was filmed in both normal and widescreen.
I now want to make a widescreen version of this.
When I capture is it important what setting the properties is on? Does it have to be 6:9 for capturing? I know I have to capture it using split scene option.
mixed capture
Klaus Christo
mixed capture
Kaz
Hi Klaus Christo
This is not something that many of us will have done.
As you mentioned ‘split by screen’ I assume you are capturing via Firewire (i-link)
This is what I would try.
From file / preferences check ‘show messages when inserting first video……..
Do not use split by screen
Start a NEW project
Capture my 16:9
At the end of capture VS will change the project properties to match the captured clip.
Select Yes to accept the change.
Delete the captured file from the timeline.
Capture the 4:3
Save the project.
From the Edit Screen and Timeline View
Drag the 4:3 image to the Overlay Track.
Right click the preview to select additional options to allow you to resize the frame to 16:9
You will lose some of your 4:3 image around the edges.
Render the video (share create video file –same as project settings.)
You now have two 16:9 videos to make one movie.
Let us know how you get on.
Others on the forum may have different ideas, interesting.
Trevor
Start a NEW project
Capture my 16:9
Capture the 4:3
Save the project.
Trevor
