Can't save my images as jpg, only ufo
cinmcw
Post by cinmcw »
I can only save my images as ufo files. This happened to me once before, but when I ran my antivirus scanners, the problem was resolved. This time, however, this resolution didn't work. Please help!
Thank you very much!
Cindy
heinz-oz
Post by heinz-oz »
Image properties, PI version, OS etc.?
cinmcw
Post by cinmcw »
Scrapbook page, PI8, Windows XP
I was able to drag each image to another blank page and redo page that way (and save in jpg). Thank you for your reply!
heinz-oz wrote:Image properties, PI version, OS etc.?
JenT
Post by JenT »
Cindy-are you using PI's Image Optimizer (F4) or going through the menu File/Save As to save your image?
Going through the Image Optimizer (F4) will only give you three choices: JPG, GIF and PNG. Depending on which format you choose, you have to enter your save preferences there. (Like a JPG at 85 compression, Standard Optimized (don't pick Progressive!), No subsampling, etc.)
If you are using "File/Save As/Save as type" for saving your images, you'll get a lot more options in saving your file. The default for that dialog box is .UFO, but if you click on the little arrow on the right, you'll open a drop down menu with the other file extensions you can use.
If you don't have any other extensions available there, then you need to change your settings in PI's Preferences/General/Open & Save dialog box. Make sure you have "List all File Formats in Save As Dialog Box" checked. Then click OK and exit PI. The options should show up the next time you open PI.
cinmcw
Post by cinmcw »
Thank you so much for your help! Actually, I am going through the menu File/Save As to save my image. This has happened to me twice now so I don't know what is going wrong. I'm just hoping it doesn't happen again! :)
VT Photog
Post by VT Photog »
[quote="cinmcw"]Scrapbook page, PI8, Windows XP
Just guessing here, but did you remember to merge all objects prior to attempting to save? the .jpg format does not support objects, so you can't save a picture with them that way.
brian
JenT
Post by JenT »
Ah, but if you save your image as a JPG through PI's Image Optimizer (F4) and not through the "File/Save as" menu you don't even have to merge your objects to the base image. :D
If you accidently have one of your objects selected, as you go into the Image Optimizer, PI will ask you if you want to optimize only the single object or the entire image. Check "Entire Image" and PI will take in the entire image, objects and all.
This way you can have your cake and eat it too because you can save your image as a UFO file and continue to edit it, while saving the work in progress as JPGs.
Win/Win situation in my book.
