Will PictureShow3 let me select more than one background music file. Wanting to play 3 different songs during slideshow, one after the other.
Thanks alot
pictureshow3 background music
angrakiller
When you are editing one slideshow, you can apply multiple background music files.
On the “Advanced Audio Settings” window you can for example drag and drop one music file form the browse panel to first picture, and then drag and drop the second music file to the second picture. After that you will hear two music files when you click the “Play slideshow” button.
wbader
Yes
Simply select multiple mp3 files with the ctrl key held down. Then drag the group and drop on the file slide. They will play sequentially. You can modify the order by selecting 123 (I think that's the button). I haven't four a way to individually select mp3s, so they need to be in the same directory so you can select them together.
Regards
...Wes
Regards
...Wes
ryandmi
Re: Yes
[quote="wbader"]Simply select multiple mp3 files with the ctrl key held down. Then drag the group and drop on the file slide. They will play sequentially. You can modify the order by selecting 123 (I think that's the button). I haven't four a way to individually select mp3s, so they need to be in the same directory so you can select them together.
Regards
...Wes[/quote]
wouldnt it play the 3 mp3s at the same time? because one time i drag mp3 file to pic 1 and and another mp3 to pic7 and what happened is when it reached pic 7 both mp3s played at the same time.
Regards
...Wes[/quote]
Masami
