ANYONE ANY IDEA WHEN THEIR WILL BE AN UPDATE
tomthum
Post by tomthum »
SOME SERIOUS PROBLEMS WITH THIS PROGRAM pI11
I dont no what the testers done but they Never tested this program
it SHOULD NEVER had been relesed with the number of Fails AND bugs etc etc :evil:
Tom thum
tomx
tomthum
Post by tomthum »
anyone information on update
please
Thank You
tomx
Ast2001
Post by Ast2001 »
+1
What are they doing ? Are they reading all the message here complaining for the very bad quality of PI11 ?
2log
re: ANYONE ANY IDEA WHEN THEIR WILL BE AN UPDATE
Post by 2log »
On the contrary, PhotoImpact is a stable program. I for one do not experience any of the problems that are submitted to this forum. And there's a lot more of users like me. But of course, the ones who will most likely post here are those (very small percentage of users) who are having problems with the software. You can't really help these problems from occuring. Not every single computer in the world have the same settings and softwares installed. Then of course, there's the usage factor.
The fact of the matter is, if you want to have the patch released soon, users like you would have to help. Submit your system information and sample files that are being used when you experienced the problem. Because unless Ulead can simulate the problems you are describing, it won't be able to release a patch for it. You can't fix what ain't broken. :wink:
http://phpbb.ulead.com.tw/EN/viewtopic.php?t=8103
OmenLW
Re: re: ANYONE ANY IDEA WHEN THEIR WILL BE AN UPDATE
Post by OmenLW »
2log wrote:On the contrary, PhotoImpact is a stable program. I for one do not experience any of the problems that are submitted to this forum. And there's a lot more of users like me. But of course, the ones who will most likely post here are those (very small percentage of users) who are having problems with the software. You can't really help these problems from occuring. Not every single computer in the world have the same settings and softwares installed. Then of course, there's the usage factor.
so you can honestly say your screen capture utility in PI 11 is working flawlessly? i dont know anyone with a working screen capture util..
2.4GHZ P4
1.5GB Ram
MSI 865PE Neo2-V Mainboard
Radeon 9600XT
200 GB Western Digital 7200 RPM HDD
300 GB Western Digital 7200 RPM HDD
WinXP Pro SP2
[img]http://img16.imageshack.us/img16/1378/ghetto5nt.jpg[/img]
Ast2001
Post by Ast2001 »
PI11 a stable program ??? Are you joking ?
PI10 was a stable program. Not PI11.
The problems I encounter are well know.
Just two questions:
. can you access to the screen capture setup dialog (that's very important for my daily work) ?
. haven't you got any gpf when launching PI11 ?
2log
Post by 2log »
Yep - I can do screen capture with no problem.
What's gpf? If you're talking about loading problems, then I'd say I've never encountered any...
Ast2001
Post by Ast2001 »
. You can access to the screen capture setup dialog (activated with the Ctrl + Shift + E sequence key or the menu File / Screen Capture / Setup) with PI11 ???
. As for the problems during loading, five minutes ago, i've launched PI11 three times before succeeding !!! The two first launchs where aborted by an error in module u32Jpg.fio
OmenLW
Post by OmenLW »
Ast2001 wrote:. You can access to the screen capture setup dialog (activated with the Ctrl + Shift + E sequence key or the menu File / Screen Capture / Setup) with PI11 ???
yeah "2log" im interested in what the screen capture setup looks like...
please post some images of it so we can see...
so if you could be so kind as to take a screenie of this mysterious panel only you can seem to access
2.4GHZ P4
1.5GB Ram
Radeon 9600XT
WinXP Pro SP2
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
BTW, PI11 TBYB damaged also PI10's screen capture setup. Fortunately, after uninstalling 11 and repairing 10's installation all came back to normality.
X.
OmenLW
Post by OmenLW »
Xyzzy2 wrote:BTW, PI11 TBYB damaged also PI10's screen capture setup. Fortunately, after uninstalling 11 and repairing 10's installation all came back to normality.
X.
holy ***... i ran the "repair" on PI11 and screen capture works in PI11 now...
BUT
my paint tools still get stuck on the edges of my projects...
2.4GHZ P4
1.5GB Ram
Radeon 9600XT
WinXP Pro SP2
Ast2001
Post by Ast2001 »
OmenLW wrote:holy s***... i ran the "repair" on PI11 and screen capture works in PI11 now...
OmenLW, can you tell me how you can 'repair' a PI11 install ?
If I use the add/remove feature or if I use the original installation file, the only choice I have is to remove all the components !
Thank you for your reply.
Michel.
2log
repair
Post by 2log »
Reinstalling the software would be a better option than simply repairing it.
When you install a software, the installer extracts temporary files needed for the installation on a temp folder. These folders are usually:
C:\Windows\Temp
C:\Documents and Settings\[User Name]\Local Settings\Temp
If the temp folder holds old installer files that may be corrupted or are duplicates with the same filename but are used for a different software, it could cause a problem for your new installation of the software. Before you reinstall the software, make sure to clean the Temp folders.
The Local Settings folder is a hidden folder so you have to enable Windows Explorer to see hidden files and folders. Open Windows Explorer, go to Tools > Folder Options > View and check show hidden files and folders. You can now open the Temp folder from the Documents and Settings folder and delete the files there before you make a new install. :wink:
Xyzzy2
ram: 8 GB
Post by Xyzzy2 »
Not the exact case, but reinstall didn't help me, but repair- yes.
X.
Ast2001
Re: repair
Post by Ast2001 »
2log wrote:Reinstalling the software would be a better option than simply repairing it.
I have uninstalled PI11
I have deleted all the entries in the two temp directories.
I have reinstalled PI11.
I always have some crashes during the startup process (in my case, the first crash has occured with the first launch !!!).
But ! Now, I have acces to the screen capture setup dialog !!!! It was a _very_ important problem in my case and this one is now resolved !
Thanks to all.
Please accept apologies for my broken english.
Michel.
Paris, France.
