Please HELP VS9 "Error on writing file 0xc00d0bc5 HEL
mokha
Post by mokha »
Please help I am getting the following error code "Error on writing file 0xc00d0bc5. I have uninstalled and reinstalled VS9 and no matter what I do I still get the error. Does anyone know any software or files that conflict with VS9 so I can find them and remove them. Before I purchased the software I used the trial verison which worked fine, but this one doesn't. I installed it on another computer and it worked fine. Please any help would be greatly appreciated[/u][/i][/b]
Winifred
motherboard: LENOVO LNVNB161216 U3E1
processor: Intel Core i7 1.80GHz
ram: 8.0 GB
Video Card: NVidia GeForce MX150
sound_card: Bluetooth Audio Dev_Realtek High Definition Audio
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: 17.3 inch FHD (1920x1080)
Corel programs: Video Studio Ult 2018
Post by Winifred »
There is obviously a conflict in files. This may be nonsence, but you can try it. Uninstall VS9 and run the windows install clean up utility - if you haven't got this you can download it from:
http://support.microsoft.com/default.as ... -us;290301
where you will find a description of the facility. USE WITH CAUTION
Once installed run the facility Select and remove only the VS9 folder and delete it. Then go to Program Files and remove the VS9 folder.
Restart your computer.
Before you run any programs clean up your DocUments\Local Settings\Temp and delete everything in that folder. You might receive an error that some files are in use if so skip them. This takes some courage!! The only program it might effect is Adobe Reader, if so just reinstall this program.
Then you can reinstall your VS9 and hopefully everything should work properly.
