MF4 Update Pack 2, build 4.03 install problem
Frankg
Post by Frankg »
I just bought a new DVD burner, came with MF4. I installed the software, seems to be working okay, got it resgistered, and now I'm playing with it.
Decided I'd check for any service packs, just to be sure I had any patches that might be available installed before I got into trouble. Found the update pack, downloaded it okay, but when I try to execute it it tells me "Setup can't find Ulead DVD Moviefactory 4.0 on your system." If I launch the program and have it running in the background, the installer tells me It can't install because "Ulead DVD Moviefactory 4.0 is running."
Anybody else run into this?
I am running XP sp2, and my home volume is _not_ C:; it's L:. Any chance that's causing the screw-up?
Uryel
Post by Uryel »
Yes I was having a similar problem. My MF4 came in a bundle of MediaStudio Pro 8. I cannot update it, nor locate and download the content for it. Ulead tect support informed me that since it's a bundled version (and not a separately-purchased one) - I cannot update it and am not entitled to free content. Perhaps your situation is similar.
Since I have both Adobe Encore DVD and Ulead DVD Workshop 2 - I figure I don't need this MF4 after all. My recommendation is that you abandon MF4 and switch to a serious DVD authoring application.
ploggy
Post by ploggy »
the patch is for full versions only. OEM versions are customized depending on the request of the OEM partner. If there is a need for a patch, the OEM partner and Ulead should work together to make the patch.
Who? Me?
jcc
Post by jcc »
I have previously read something which implies a bit of confusion about where DVDMF.exe is supposed end up installed. In my installation which successfully accepted the update it is...
C:/Program Files/Ulead Systems/Ulead DVD MovieFactory 4.0/Ulead DVD MovieFactory 4.0/
Maybe yours is not the same?
Frankg
Post by Frankg »
Mine is installed on:
L:/Program Files/Ulead Systems/Ulead DVD MovieFactory 4 Suite deluxe/Ulead DVD MovieFactory 4.0/
jcc wrote:I have previously read something which implies a bit of confusion about where DVDMF.exe is supposed end up installed. In my installation which successfully accepted the update it is...
jcc
Post by jcc »
I would try renaming the directory, running the update and then renaming it back.
