BURNER IN USE FOR ANOTHER APPLICATION - FIRST TIME USER
REDMAN
Post by REDMAN »
HELP!!
FIRST TIME USER -
I can get to the point where I appear to be burning a DVD-VIDEO file to a DVD-R disc but at 65% completed, I get error message - BURNER IN USE FOR ANOTHER APPLICATION
None of the other drives on my PC are in use and I cannot understand which device it is referring to??????????
I am using DVD MOVIE FACTORY V4
DVDDoug
Moderator
Post by DVDDoug »
Probably Nero, Roxio, or some other "packet writing" software has hyjacked your burner. You can try de-activating whatever is confilcting.
Or, choose Create DVD Folders, and uncheck Record To Disc. This will create the VIDEO_TS & AUDIO_TS folders on your hard drive. Then you can use your regular burning software to copy these files to the actual DVD.
jcc
Post by jcc »
Remove Ulead's Data Add program if you want to retain the use of previously used packet writing software.
ploggy
Post by ploggy »
This problem has been corrected in the 4.03 patch....
Who? Me?
