I spent the better part of two days synchronizing 280 pictures to 4 songs and then when I viewed the VCD I burned my slideshow did not sync up.
It was perfect when running on my PC. Has anyone else had this problem and found a solution.
Slide show out of sync after burning VCD
scottruth
I've had this problem as well. I put together a slideshow with probably 60 different slides, transitions, etc... When I go to create the video file under the share tab, depending on what output format settings I give it, I get some video out of sync and some video in sync but with unacceptable compression distortion. I'm using version 7.01.
jjabo
