burning to dvd-rw
videojojo
burning to dvd-rw
when i attempt to burn to a dvd-rw disc (that already has recorded material on it) videostudio wont let me because there is not enough available space on the disc. how do i force videostudio to record over the old material on this disc (it being a rewrittable disc), thanks. is there some sort of format or erase disk function in videostudio9.
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
videojojo
dvd-rw procedure
is the recommended procudeure to first erase/format a dvd-rw disk which already has recorded material on it or should i just be able to put it in the drive and expect the new material to be written over the old
The Erase Disc option should become active when VS recognises the disc as a RW type.
Look at the ‘Disc Information’ in the upper panel.
If it reads ‘Empty’ then your dvd drive is not reading your disc. Not a VS problem, but maybe a compatibility problem between your disc and burner.
There is no recommended procedure for using different types of disc.
Although Ulead do have a compatibility list of burners and discs on there web site.
I have used RW disc’s with success, VS overwriting the disc, but on occasions would not work until I erased the data.
If you have other burner software such as Nero, use that to erase the disc.
Trevor
Trevor
