clips in storyboard
ronnybob
clips in storyboard
Post by ronnybob »
I have video studio 8 se, I am not able to put no more than one clip in the storyboard at one time and I believe that is the reason I am not able to trim my video. I followed the step by step info but when I get to a certain spot my program does not match the directions. The pictures in the helps area have multiple pictures
in the storyboard I can only get one, I've spent two days trying to figure this out and I give up I need help.
Post by Trevor Andrew »
I am not quite sure what you are doing.
You can edit in Storyboard View or Timeline View. There are Three buttons to the left of the timeline click to select the options. The lower one is the Audio View.
In Timeline View (the middle button) you view the clips in a continuous strip.
If you cannot see all the frames, go to File – Preferences – Clip playback mode select ‘Thumbnail Only’
Trevor
ronnybob
storyboard
Post by ronnybob »
Yes that worked, I have all the thumbnail pictures. Now the next problem is to cut out the commercials. I think I can do that in time line?
