Error 0x800411da(4570) at end of movie/fac 4
Gipetto
Post by Gipetto »
After putting together my second photo slide show with 8 chapters it fails during rendering etc with the error message 0x800411da(4570).
So frustrating as it happens after 45 minutes after the start and I can't find any reason orexplanation!!!
Any help would be appreciated.
Running on XP Home, Sony Vaio laptop with over 4 gig spare on hard drive.... Length of project just over a gig for 37 minutes worth.
Gipetto
annieblacklab
0x800411da error
Post by annieblacklab »
Did you ever find the solution... I'm having same problems today.
Hi Gippeto, welcome to the forums..:)
I'm not sure what that error message is. However you did supply a bit of information that may be what is preventing the disc from being burned.
Having 4 gig of free space for creating video is not much. In fact with your project being 1 gig in dize, it is pushing the limit. When the project is being rendered, and then burned, DVD-MF needs additional temp space to put it all together. So for a 1 gig project, it will need at least 2 gigs to work with.
Another culprit is applications running in the background. Anything from screensavers, to antivirus, spyware, all consume cpu and could spring to life, which could cause the application to stop, stall, or lockup because the resources have been taken away from it.
For the least amount of trouble with burning discs try to disable all background applications, and if you can free up some space to give MF some room to work with.
Those may not be what's causing the problems, but until we know, we have to at least eliminate them as possiblities..
Sony is also known for proprietary hardware and software. They want you to just use their stuff. I have read in the past where some burning software of Sony's simply will not allow anything else. What Sony applications do you have installed, that deals with capturing or burning?
Regards..
Gipetto
Re: 0x800411da error
Post by Gipetto »
annieblacklab wrote:Did you ever find the solution... I'm having same problems today.
It was a long time ago now but I did manage to succeed by trying again and again.
I think video man probably identified one or more of the problems???and I did close everything running in the background including virus applications. I have since added some more ram memory. I found the programe made the computer grind so slowly it was painful to watch with just 512meg. Added 256 more and computer works much better and helps the Ulead prog.
Sorry cant be any more help.
Gipetto
Gipetto
Post by Gipetto »
vidoman wrote:Hi Gippeto, welcome to the forums..:)
Regards..
Thanks for your input. I replied to another member who no doubt will have read yours... Gipetto
