VS 9 Upgrade
mronion
VS 9 Upgrade
Post by mronion »
I have VS 8 and about to upgrade to VS 9, At present i am half through editing a video, and am concerned that i may lose this work. Is it ok to upgrade or is it better to wait.
Thanks for your help
Pete
Post by Trevor Andrew »
Although recommended to remove earlier versions there are many that are running several versions of video studio.
Your video projects should be compatible with VS 9, using both versions allows you to complete your work.
Trevor
jchunter
Post by jchunter »
I have consistently had problems when making video files using VS9 from mpeg2 files that were edited with VS8. The workaround is to turn off Smart Render in VS9 but the situation is annoying and time consuming. It is not clear if the problem arises from editing or from inserting complex transitions. Therefore, if I were you, and this were my first project, I would begin using VS9 immediately and recreate the project from the captured video files.
John
Hi John
I am assuming you are talking OSS.
Its about time Ulead produced a fix for this problem without having to upgrade to Vs 9.
As far as I can see VS 9 does not have the oos problem.
So where’s the fix for VS 8 (the technology is there) (annoyed)
Sorry I digress from the original post.
Trevor
jchunter
Post by jchunter »
Trevor,
No, I am referring to actual video file corruption, including stalling, stuttering, freezing, blockyness, etc. Whenever I open a VS8 project from my archive in VS9 and create a video file using Smart Render, I get at least one of these symptoms.
The OOS problem is yet another VS8 problem. Some users have reported they have no OOS problems now, but we all heard that story most of last year. The problem was hugely exacerbated by Ulead's update release policy of changing the content of the update file without changing its name: we all had different versions of the burning engine, depending on the date we downloaded the update... :shock: :shock: :shock:
I recommend never using VS8.
John
