how to remmove video from inside a clip
petercli
Post by petercli »
using vs9.
i have a 30 min. clip.
How do I remove some gargbage video from inside the clip ?
The mark in / out will not work because this is in the middle of the clip.
dgoldan
Post by dgoldan »
Split the clip using the scissor tool. Then mark in/out each end that you don't want from the two clips.
Dan
Post by BrianCee »
Or just use the scissor tool to cut the clip at the beginning of the bit you want to remove - then use the scissor tool again at the end of the bit you want to remove. Highlight the bit in the middle that you want to remove - hit delete on your keyboard - job done.
Terry Stetler
Post by Terry Stetler »
Or you can use the correct VS9 tool:
Multi-Trim
which can remove multiple segments, leaving you with just what you want. Assemble the new clips it creates end to end and you have your completed product.
Terry Stetler
