P11 installed but error on start...
Rogers
Post by Rogers »
I am a registered user and downloaded the trial version of PhotoImpact 11 to see if it was worth upgrading.
The initial installation was successful and I had a first look. The following day when I came to take a good look I got the following error message while it was trying to load.
I uninstalled and downloaded again but now get the same result every time I try to start the program.
Any ideas?
- Roger
davenz
Re: P11 installed but error on start...
Post by davenz »
Any ideas?
- Roger
Hi Roger
Usually with dll errors like this one it is an incorrect version that is causing the issue. It may be that PI 11 updated the dll and Windows is now complaining about it or maybe the other way around. You could try running the system file checker and seeing if you can restore the original (read: correct) version. Im not saying it will fix it, but it is worth a try as a starting point.
Start --> Run, type in "sfc /scannow" (without quotes), hit OK and let Windows do its thing. You may be prompted for your original windows disk (or install location).
Good luck.
Dave
Rogers
Post by Rogers »
Thank you davenz I tried your suggestion but the problem is still there :(
Do you or anyone else have any other suggestions?
- Roger
