While editing "My Library", inadvertently used the detatch command. My Library disappeared, and i have no idea as to where it went, or if it even exists anymore. Any information on this subject greatly appreciated.
P.S. I did'nt use the delete command, used detatch command.
P.S.S. I'm using PI8.
Tks. RJG
Library manager, detatch command
JenT
If you used "Detach" and not delete it should still be there on your hard drive. Do a search on your hard drive for *.UOL to locate it (if you used the default PI My Library, it's probably in the PI8 program folder) and then use the Easy Palette's Object Library Manager to import it back into your EP.
Just a suggestion, though, create your own Library tab outside the PI folder. It's much easier to back up and if you have to reinstall PI for some reason, your own objects won't be at risk of being deleted.
Hope that helps.
Using PIv8 with Win98SE, on a HP VectraVLi8 500MHz PIII with 256M RAM and a Matrox MGA-G200 AGP graphics card with 8M memory.
"If it ain't broke, don't fix it!"
Hope that helps.
