VS9 Capture problem
silviu1
VS9 Capture problem
Post by silviu1 »
Hi everybody,
I'm trying to capture (DV1 format) using the firewire connection on a PC - Windows XP SP2 - that has an AMD 1.5 GHz processor with 512 Mb of RAM . I have this two problems:
1. With the tape playing when I hit capture I always have a blank screen for a few frames after the first few frames are captured. When I hit stop capture the tape stop playing every time. Shouldn't the tape keep playing ?
2. I cannot use the jog wheel (with the cursor) to control the camera playing speed. All other functions controlling the camera work just fine.
I tried this on both my camcorders a JVC GR-DVF 31 and a Panasonic PV GS-400 with the same results.
Can I get some ideas here ?
Thanks,
Silviu
Re: VS9 Capture problem
Post by Trevor Andrew »
silviu1 wrote:Hi everybody,
Not sure about the blank frames,Put the camera in stop or pause not run before pressing capture.
The camera should stop, see File/Preferences/ capture tab.
silviu1 wrote:2. I cannot use the jog wheel (with the cursor) to control the camera playing speed. All other functions controlling the camera work just fine.
Thanks,
Silviu
The jog wheel seems to wiork on my set-up, although it does open a slider rather than turning a wheel(using Panasonic PV GS-400)
Trevor
