So, I'm seeking an good combo of settings to capture VHS (via NTSC) for making a DVD that will play on a TV and on a computer at 640x480 (or ideally larger). I tried capturing at high res for PC display but the settings dropped a zillion frames. Too much horsepower I guess to capture hi-res at 30 fps.
My DV work always imported my camera's DV stream directly to AVI with little hassle and no frames dropped. However, when doing a raw NTSC capture from VHS deck, I'm overwhelmed with all the possible combos of CODEC, resolution, and bitrate and haven't found one that works well. Higher res drops frames or produces jerky motion. Lower res doesn't fill the screen. Other combos trash the quality or don't work at all.
I know there's no single solution but I figured there might be some generic combos that usually work well for what I had thought wold be a very common need (converting VHS for DVD).
I have a 1.7 Ghz PC, a decent capture card with NTSC input, as well as FireWire inputs I use for my video camera captures (works well). I also don't have any problem getting the NTSC input to work - it's just the CODEC, bitrate, and resolution that are confusing me for the capture process itself. Must be a senior moment. Once captured, I will then create a DVD with some menus etc. Since some of the videos are 2 hours, I can't capture directly to AVI which would require a monster storage array.
I'm getting results but they are poor (jerky, or low res, or low quality). Anyone have some thoughts, pointers, or suggested combos that won't further degrade the low quality of VHS and that will play well on PC's and DVD players. I'm trying to avoid testing another 1024+ combinations
Thanks to all.
