Hello
I can get a Title to fade-in or fade-out using animation, but how can I get a Title to fade-in, stay steady for a while then fade-out?
VS9 Title fade
It is an option in animation configuration for the title. you can pick how long you want it to stay based on canned selections. I am in the middle of a burn right now, so I can't give you specific details, but I am sure it is one of those cog wheels.
Bruce Bennett
VideoStudio 11+ (started with VS5)
PhotoImpact 12 (started with PI11)
Two ways:-
1 / Select animation, select ‘fade’ as Type, Click the two ‘TT’s for more options.
Here you can select long or short pauses
2 / make three titles one to fade in one static the other to fade out.
Create the first title then drag it to the library, a thumbnail is made , drag the copy back to use again, just change the attributes, this way the text should be in the same position.
Hope that helps
Two ways:-
Hope that helps
