Defalts to muted?
jcb2354
Defalts to muted?
Post by jcb2354 »
I have been using mf4 for several months now and have found it to do everything I want. I have burned various DVD's in all kinds of formats with no problems.
Then, for no apparent reason I lost all sound. When I would import videos they would be completely mute. I tried importing some videos of all types (mpeg,dvd,iso,dat)that worked before and all I would get is video.
I then tried going to 'enhance video', using the tab at the top to go to audio, then muting and unmuting. THEN I get the sound as normal!
I have tried repairing the files but still get this problem, I can work around it but it's a hassel and I would like to know what I did to set it to mute as the default. (more important, how do i UN-SET it!)
progrocktv
Re: Defalts to muted?
Post by progrocktv »
jcb2354 wrote:I have been using mf4 for several months now and have found it to do everything I want. I have burned various DVD's in all kinds of formats with no problems.
Yes, I have the SAME PROBLEM. Except I wasn't aware of the work around, thanks;-) Any ideas on how to fix this?
jcb2354
Not a fix, but this is what I ended up doing.
Post by jcb2354 »
I had the problem of having installed Roxio, and many years before Nero on my computer, I found that many of the extra drivers and reg entries were not removed and I assume that this was causing some of the conflicts. When I tried removing the drivers I would loose the DVD drive completly.
My final 'fix' was to back up everything, wipe the drive and start over. I have had the machine for 5 years now so I was getting funky messages in several programs, the registry was getting out of control and things were becoming painfully slow.
This did fix the problems with Ulead, except I still cannot record at over 6x without getting error messages, but that could be the media.
Best of Luck,
JCB
stevenk
same problem
Post by stevenk »
Me too. Being able to work around the problem is helpful, but has anyone been able to find a fix for the problem yet?
