PS4 Photo Impact Pro v10 w/Photo Explorer 8.5
cherylhalsey@adelphia.net
Post by cherylhalsey@adelphia.net »
Below is the problem I'm having with the above application this problem applies to Photo Explorer 8.5 as well( Installed from CD only). Could somebody please help.
PS4 keeps shutting down tried to reinstall from (originally install from download) newly received CD the ini file is corrupt. Originaly install from download PS4 ulead website and it keeps shutting down while trying to create a slideshow, it does not matter what I'm doing it keeps shuting down. Adding images shutdown, adding audio shutdown, burning cd shutdown and hanging. I have to save after each thing I do, then the application shuts down, and I have to restart my system and then I can continue and then I start all over again the same sequence of steps: add, shutdown and restart. At this point I not a happy camper after purchasing two application and their both having problems. Your support site sucks there is no support for the versions I have recently purchased and after reading the support forum replies I guess I have been screw by ulead. I'm a newbe to your products and would like to have faith in your response please help you can contact me at 216-371-8954 :evil:
Marla
Take a breath and try again.
Post by Marla »
Edited
Hi, ch:
Let's try this again:
Try to make your problem clear. Use the full names of the products you are having problems with. One at a time.
Does your computer have enough memory?
Do you have a folder open that has many high-resolution images in it? Close it first. Close things that are not pertinent to ULead and its installation.
Take it from the beginning again. Tell us step-by-step:
1) What is it that you are trying to do with ULead;
2) The ULead applications you are working with;
3) The media you are using to accomplish your installation;
4) The computer you are using.
Slow down and let the users in this forum help you.
Sincerely,
Marla
