daniel wrote:DCP:
If you're not sure what your hardware does, there is always the "auto-detect" option before capturing to give a hint (not 100% accurate).
It's more important indeed not to mix styles (upper/lower) than having the right one for VHS.
An easy way is to capture 5 minutes of video with hectic movement (not the news speaker for instance), film company moving logos are fine too, they often show smooth movement, color shades moving etc.
Then you go through all the steps, capture, MPEG, DVD(RW if want my advice) for both field orders and watch the results attentively on the TV m.
**WARNING**
THE FOLLOWING CONTAINS MUCH VENTING OF FRUSTRATION..LOL.. NO ONE IS TO TAKE THIS PERSONALLY. DON"T READ THIS IF YOU CARE TO MAINTAIN YOUR SANITY BECAUSE I HAVE LOST MINE JUST THINKING IT!
Here is how lost I REALLY AM !
Hey, If you wanna substitute the word STUPID for lost, thats ok too, because I am really beginning to think that must be my problem. I read and read and still don't get it.
I have not begun to convert all my analog stuff yet because I can't be satisified merely accepting a good or bad final outcome by a flip of the coin. "If this setting doesn't work .. switch it and try again" I'm not blaming your explanation ... EVERY explanation says that. WOW .. good thing thats not how to check for live circuits in a house when we go to wire it. There would be lots of folks with black fingertips and straight hair.
Not only am I not sure how my hardware captures ...I was under the impression that it didn't dictate field order, since, in order to run it, I have to use a capture software program, and all of those programs have "pre capture" setting that ask you how you want to capture. My hardware did not come with its own program. Hey what did I expect for 400 dollars . <sigh> I mean, if my hardware (Canopus 300) is preset to capture in a particuar field order, (there are no settings to change field order, nor is it mentioned in the instructions.) then why the #$% don't they put some card in there that says... THIS HARDWARE CAPTURES IN LOWER FIELD FIRST. Not that it matters anyway since I can't use it without a software interface which I can't use either unless I choose a field order setting from within that software first!
Geez .. what are we supposed to do experiment with every single element of every single hardware and software device we buy to capture some stinking video. Boy is this starting to get to me.
Ok, now auto detect, is this a part of VS9? If so, what exactly is it detecting? The incoming field order from my hardware device prior to the software settings in VS9? I mean if hardware really is capturing in the MFG. preset, then would it not make more sense for editing software to ask the question of field order by saying choose >> standard or reverse incoming field order.
I know this isn't making any sense to anyone. But, its like, do two negatives equal a positive. If my capture device captures in LFF and I set my software to LFF, do I get a different result than if my hardware captures in UFF and I set my software to LFF?
Capture five minutes EVERY TIME I use my program on a different project? Is that what you mean? The Movie "MY COUSIN VINNY" comes to mind when he says about grits.... are the laws of physics for cooking grits different in your house than anywhere else? LOL ..I mean which is it Upper or Lower. <whew>
I can picture, way back in the beginning, when the original film was being shot, one camera guy says to the other, "Hey Mel, waddia got your camcorder set to upper field first of lower field first?" "I dunno, whaddia think?" "Spin the wheel.. lets see what it picks". "Hey wait a minute Mel, my camcorder don't got no field order setting on it" LMAO .. BOY I"M LOOSING IT!
The only reason I thought capturing in AVI was a better choice was, as I understood it, it is less likely to drop frames than trying to compress on the fly while capturing to mpeg. My computer should be fast enough to handle it, but ... why risk the complication, when I'm trying to figure out what I'm doing and by the sounds of "on the fly Mgeg" capturing, I merely adding another variable to the confusion.
Disk space isn't an issue, its gonna have to render anyway, and to top it off, I am reading that editing with mpeg clips is not as good as using AVI.
I am so lost I am actually beginning to get frustrated. Is there not a book, an all in one location guide, some "from square one" explanation of this stuff. This is getting ridiculous. It seems that with every explanation I read I am carried off onto another learning tangent just to decipher the explanation.
I can't believe that the answer is flip a coin and try it.
OK, there ya go, I'm officially burned out by this ..LOL.. Maybe catching butterflys is a better hobby. But would I swoop the net from the top down, or from the bottom up?
