"save as" doesn't work - FIXED!!!
JAKE
Here's mine. I can't "save as." WhenI try to save using "save as" the "save button is grayed out until I type something inthe file name box. Then When I hit "save" nothig happens. Absolutely nothing. It just sits there.
I purchased the upgrade CD direct from Ulead. Am running Xp Home SP1.
jmattos
PI11 "Save as" does not work
Noticed no one has responded to your post and thought I would add my support - I also can not use the "Save as" in PI11. "Save" works fine but it is extremely inconvenient not to be able to save a digital camera image original or any other image with a different name. Maybe the next update will fix this and other problems.
JAKE
Re: PI11 "Save as" does not work
Sorry to hear that you have the same problem, but am a bit relieved that I'm not the only one. Gives me hope that its not just my unique problem and that Ulead will find a fix.jmattos wrote:Noticed no one has responded to your post and thought I would add my support - I also can not use the "Save as" in PI11. "Save" works fine but it is extremely inconvenient not to be able to save a digital camera image original or any other image with a different name. Maybe the next update will fix this and other problems.
pijulian
heinz-oz
Since I don't have PI 11 and therefore cannot try to reproduce your problem, have you tried this possible fix? http://phpbb.ulead.com.tw/EN/viewtopic.php?t=7822
JAKE
JAKE
VT Photog
Re: "save as" doesn't work
I haven't gone with PI 11 yet, still using 10. I am guessing here, but are you trying to save a RAW image from your camera? You may need to specify a format, or, if trying to save as .jpg, convert image to 24 bit color first. If you try to save a 48 bit image, it won't work with .jpg or some other formats.JAKE wrote:Here's mine. I can't "save as." WhenI try to save using "save as" the "save button is grayed out until I type something inthe file name box. Then When I hit "save" nothig happens. Absolutely nothing. It just sits there.
brian
JAKE
No. It doesn't matter what file format. "Save As" just doesn't work. Ulead has told me its a known problem some people are having and they are working on trying to duplicate it on their machines so they can find a fix.VT Photog wrote:I haven't gone with PI 11 yet, still using 10. I am guessing here, but are you trying to save a RAW image from your camera? You may need to specify a format, or, if trying to save as .jpg, convert image to 24 bit color first. If you try to save a 48 bit image, it won't work with .jpg or some other formats.JAKE wrote:Here's mine. I can't "save as." WhenI try to save using "save as" the "save button is grayed out until I type something inthe file name box. Then When I hit "save" nothig happens. Absolutely nothing. It just sits there.
brian
themaxer
Save as problem in PI11
It appears to have something to do with the version that is included on the upgrade disc.
cardlady
I just received my PI 11 and hadn't had a chance to use it yet, but tried to save as, and it saved fine....try clicking on options and check off compression to RLE. I am just guessing but might work.
If it is a bug, I don't understand that it works on some programs and not others. I did send for the boxed version, did you download?
Annette
Annette
JAKE
You don't seem to understand. It doesn't work. Ulead has acknowledged that its a problem for some users. The options dialog box does not even come up.cardlady wrote:I just received my PI 11 and hadn't had a chance to use it yet, but tried to save as, and it saved fine....try clicking on options and check off compression to RLE. I am just guessing but might work.
Annette
Bruno_G
Here's another one with same problem... Saving images "as" (e.g. scanned or opened from hard disk and modified) does not work, whether it be in jpg or bmp format. The "save" box remains greyed untill a moment, but when it's available and I click on it, nothing happens... Well, at least, application does not crash...
It sounds incredible that such a bug happens in such application !
I'm running WinXp SP1 and PI11 (downloaded trial version).
Reading the above comments, I realize nobody has the solution.
I hope the programmers will fix this soon.
bg
bg
