Alpha channel with .ufo file?
richardnau
Post by richardnau »
I use MediaStudio Pro for video editing. The blurb for MSP 8 states that
PhotoImpact™ UFO files can be directly inserted in the timeline, maintaining all objects and alpha channel.
Well, I can certainly insert a .ufo object into the MSP timeline, but for the life of me, I can't figure out how to get PhotoImpact (ver 10 or 11) to save an alpha channel with a .ufo file. No problem generating and working with alpha channel in .png files, but I'd love to be able to work in the .ufo format that preserves objects...
Any hints?
Richard.
JenT
Post by JenT »
Don't have MediaStudio so couldn't tell you, but I do believe that the alpha channel in PI is a selection. Save your UFO with the selection highlighted and see if that doesn't work.
Otherwise, maybe post this in the MediaStudio forum, if you haven't already done so. (Any chance there's a tutorial on the Ulead Learning Center site?)
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
I think that the Mask is Ulead's name (and function) for alpha channel :?:
X.
plasma_video
Post by plasma_video »
Try making your images with a transparent background. When you create a new file, it will give you the option to create the image with a transparent background. Then create your objects in the work area. I believe that is what MSPro will be looking for as the alpha channel, like a PNG with transparent BG.
I do lower third supers that way and save as PNG with the transparent background intact, and my editing programs use it properly as if it were an alpha channel.
This trick does not work for TGA files, however, due to the interpretation of TGA specs. For TGAs you must use the selection mask as your alpha channel. It is a bit of a convoluted procedure as to how to do this for tga, but if you are interested I can post more details.
rwernyei
Post by rwernyei »
I use TGA image sequences with background transparency selected in my 3D software all the time. MSP has no problems identifying the alpha channel. In the Overlay Options, under Type the Alpha Channel will already be selected. No special procedures required.
ploggy
Post by ploggy »
Here a link for making alpha with TGA and TIF.
http://www.ulead.com/learning/msp6_7/page1.htm
For UFO, the Save selection is greyed out because any selection in the UFO file is automatically saved with the remaining areas as alpha channels.
Who? Me?
plasma_video
rwernyei wrote:I use TGA image sequences with background transparency selected in my 3D software all the time. MSP has no problems identifying the alpha channel. In the Overlay Options, under Type the Alpha Channel will already be selected. No special procedures required.
That is true. I was refering specifically to creating TGA with alpha using PhotoImpact. MSPro does a great job with TGA and alpha.
PI requieres you to make a selection, save the selection (or selections) in the selection manager and then merge them back into the document to create the alpha in a tga export. It's a little goofy, but once you figure out the technique it works well.
richardnau
Thanks all. I now understand the issues and am successfully using PI11 to generate lower thirds for MSP.
But... I'm not using UFO files for the simple reason that a transparent UFO file does not maintain the full canvas size -- you only get the objects and the spacing between them.
I'm using PNG files with transparency (alpha channel) because frame size is retained and this gives accrate positioning on the vide screen.
Richard.
Video editing PC:
C2D E6600 CPU on Asus motherboard
2GB dual channel DDR2 RAM
7600GT PCIe video card
320GB RAID 1 SATA system drive
400GB RAID 1 SATA documents drive
400GB video drive
Samsung and Pioneer DVD burners
Vista Home Premium 32 bit
