ok, here is my problem.
i made a project with dvd workshop 2.
with 86 video clips
14 picture galleries
and lots of static menus with a .wav as back sound
im at the limit with the videos (99 total)
there are 10 main movies and the rest are transaction videos between one menu and the other
the computer was almost on flames (reachs 2000mb pf memory use)
i wan to make an audio and video ts folders
finish/burn it reads the videos ok, it reads the menus but when it reaches the burning process i get the:
"Operation Aborted" when burning
Unspecified error 80041397
the videos where avi but then i turned them into mpeg 2 (i also tested with only 1 video and 1 menu and works good but with the whole project i keep getting this error)
any clue?
im on a dead line,
thanks for your help
Unspecified error 80041397 when burning
moes tavern
i have more info of my project
its a pal dvd
ive counted the menus and there are 39 (bmp files)
after the error i can see a folder named dws_ts with 2 folders in it:
cvtmenu = with 39 sub folders (the menus)
MENUAUDIO_ 1.wav
CvtTitle = with 100 su folders (the video clips i assume)
all the folders are empty
the structure of the menu is a button that loads a transaction and the another menu, a button that loads a main movie and then backs to the same menu or a button that trigger a 3 image slide show
i have 2 menus with 15 buttons each but they mostly have 3 links
all the videos are encoded to mpeg 2 dvd pal format 720x576 25.00fps 48.000hz stereo
dont know... maybe is the huge amount of data.
since it works fine with just a couple of movies and menus i´ll try to remove some material
if you need more info please let me know
thanks
its a pal dvd
MENUAUDIO_ 1.wav
thanks
I'm sorry, but your description is terribly complicated!
What were your encoding settings? What was the size of the project? We need to know a lot more before we can even start guessing what went wrong.
