I very often get low or no virtual memory when using the above. All I have done is to load 1 minutes worth of Video background and some text with the fire effect. I leave the dimension settings as default 320 x 240 ntsc corporate. then change to pal 720 x 576 DV PAL on completion prior to create video file.
The system I am using is 160GB hard drive 512 ram. 2.8 GB processor.
Any help /advice will be much appreciated.
Many Thanks
Reg Goodyer
Low or no virtual memory when using 3Dcool production studio
htchien
How many video RAM does your video card have???
Ulead COOL 3D Production Studio - System Requirements:
http://www.ulead.com/c3ds/sysreq.htm
Hope this helps.
H.T.
Hope this helps.
H.T.
htchien
The driver in Windows for your display card might not be compatible with DirectX 8 and will need to be updated to the latest one. You can get the latest ATi display driver for the Radeon series from http://www.ati.com/support/driver.html
If you are not using Windows XP, suggest you to upgrade.
Hope this helps.
Rgrds,
H.T.
Hope this helps.
Rgrds,
H.T.
