I created a project in PS3 with 10 picture slideshows. I chose to create the DVD folders option, and cancelled while the 3rd slideshow was being created. The detailed progress displayed 'Building slideshow 3/10'. I had the following files in the working folder:
DPS0001.mpa (1.3 MB)
DPS0001.mpg (18.08 MB)
DPS0002.mpa (25.5 MB)
DPS0002.mpg (357 MB)
DPS0002.upd (1 KB)
The next day, I chose Burn to continue generating the files. This time, the detailed progress displayed 'Building slideshow 2/10'. In the working folder, it started creating a file named
DPS0003.mpg
When the process completed, I had a DPS0003.mpg and DPS0003.mpa file that is exactly the same size as DPS0002.mpg and DPS0002.mpa.
What should I do now? I am letting the process run, but the file names look to be out of sequence i.e. it's creating slideshow 5/10 now, but the file generated is named DPS0006.mpa.
Thanks for any help.
Ray Mond
PS3 processing
video files
These might be the video files needed to build your DVD slideshow. I guess you need to finish the building sequence for it to build the project sequentially and completely.
†bryave
