When I try to convert a AVI file (75 minutes of analog film captured with windows movie maker) to MPEG2 (to burn a DVD) with VS8, it takes my computer a very long time (over 10 hours ) and than at approx. 75% I get a warning that my virtual memory is insufficient. A little later VS8 closes it self. With smaller files a never had a problem. Does anyone know what I should do to get this file converted to a MPEG2 file on a DVD?
My settings:
MPEG files
24 Bits, 720 x 576, 25 fps
Lower Field First
(DVD-PAL), 4:3
Video data rate: 6000 kbps
LPCM Audio, 48 KHz, Stereo
Memory problem
Telgaladhion_Greyskye
First off, close all running apps in the background - VS needs all the resources it can get; it dislikes sharing with other programs. Unplug all unneeded external devices. If you're running on Win XP, increase your Virtual Memory this way:
Right click My Computer > Properties > Advanced > Performance Settings > Advanced tab. Next, click 'Change' to set your system's virtual memory.
This is the values I use:
Custom Initial Size: 1024
Maximum Size: 4096
Click 'Set', then your computer will ask you to restart for the settings to take place.
Maximum Size: 4096
heinz-oz
hans_kazan
Ok, I closed all of the other programs and increased the virtual memory to your suggested settings. But again I soon run out of virtual memory (even sooner, now @ approx. 37%). And after this warning the program shuts it self down (no crash).
The requested hard drive space was 8.2 GB for this project and my available is 37.2 GB.
THoff
hans_kazan
