Burning more than 1 show per disk does not seem to work. Help indicates an exact image is made on the HD but what is the name of the image? I've tried not closing the disk (Use Options) on the first show burn and then burn the second show but the disk gets closed anyway after the first burn.
1. Where is the HD image and what is its name? I see a video only file and a audio only file and something called vcd_xa.ixa.
2. Can you put more than one show per disk?
Also, I have many "Font not found" error messages. This is after I've upgraded from the 3.0SE to 4.0. Is there a fix for this?
More than 1 show per vcd/dvd in PS4
That's the image file "vcd_xa.ixa". Disc image files usually come in .iso, .ixa, and .ixb. You can also use Ulead Disc Image Recorder on burning such files.
I guess you can only burn 1 project per VCD/DVD because it contains all the slideshow you have.
You might need to reinstall your program to properly determine your fonts. Try a clean reinstall including folders and registry entries deleted from previous version.
†bryave
