freeze frame
ron92663
freeze frame
Post by ron92663 »
Is there a turorail or graphic that shows how freeze frame works? Pulling my hair out! Everything ULEAD does is intuitive except this!
Post by BrianCee »
I presume you want to show a single frame for a preset period - the way to do that is to create a still image of the frame (using VideoStudio) cut your video and insert the still image and set it's length to what you want - - or did you particularly want a diificult method ??
randazzo
Post by randazzo »
Does that do the job? I tried this and the image takes another dimension tnan the vclip does. I guess i did something wrong??
Jean-Pierre Randazzo
Post by BrianCee »
Could be you used "keep aspect ratio" instead of "fit to project size"
Else why would a frame extracted from a video be different to the video.
Post by Trevor Andrew »
Hi randazzo
It may be that you need to navigate to the last frame in your clip, then select ‘save as still image’.
Trevor
Hi randazzo
Trevor
