Can not convert certain SVCD videos
Serge_FT
Post by Serge_FT »
For some reason when I am creating a DVD some videos just will not convert. I dont understand this because if I use Sonic MyDVD they all convert fine! I have all needed patches etc...
What I want to know is how do I get around this?? Is there any way to convert the videos using a different program so that they become available with Workshop?? If so, how do I go about doing this??
Thanks for the help
Serge
GeorgeW
Not sure what happened...
Post by GeorgeW »
Not sure what's causing the problem with certain files. What are the actual attributes of the files in question (resolution, bitrate, mpeg-1 or mpeg-2, frame rate, audio type, etc.). What error do you get? Look in the DWS_TS folder for the temp files that got converted to see where it left off...
Since you were able to convert in another software, would it be possible to re-use that conversion in your new project (it might be left in a temp folder or something...
George
