Frames and Themes
Greg Burson
Frames and Themes
Post by Greg Burson »
Can anyone tell me where I can go to find out how to creat my own frames. I have a lot of custom templates I've created in Photoshop CS and would like to do the same for PictureShow ...
bryave
difficult
Post by bryave »
I think that would be difficult since PictureShow only uses the templates. And it contains configuration files and smp files that uses those information in adding these images within the slideshow even with frames also. :D
†bryave
Greg Burson
Frames and Themes
Thanks for the reply, some program has to create the frames ... thats what I'm looking for .....l
kansas
Post by kansas »
I'm looking for the same thing. I can't believe that other frames have not been created. Hope someone gives you a suggestion.
michaeltee
motherboard: HP 82F1
processor: Intel Core I5 7400 3 GHz
ram: 16 GB DC
Video Card: Intel HD Graphics 630
Hard_Drive_Capacity: 2TB Hybrid
Monitor/Display Make & Model: Samsung S24D300
Corel programs: Installed: PS Pro 2021, VS Ultimate 2020
Post by michaeltee »
Greg,
The "Props" (with transparent backgrounds) included with PS4 all have the .UFO file extension which is associated with Ulead's PhotoImpact. You could experiment by downloading the PI trial package and creating some test objects. It's definitely possible to import standard image files (i.e.; jpg) as overlay objects through the main program interface e.g. Organize > Decorate > Use Other Props, and then following a path to your new image files. So it may be that .UFO files could be sucessfully imported as well (just a guess on my part). Assuming the transparancy properties of your .UFO image objects was retained after importing, they might work as simple overlay images.
I'm not precisely sure how true "frame" templates are created. According to another user I've been in touch with, you'd have to run unknown command lines on "SmartCacheMain.exe" which apparently is the engine PS4 uses to generate the needed index files used in conjuction with various images to create templates.
I'm new to PS4 so it's all speculation at this point. Not really what you're looking for but by all means let us know if you discover anything of interest :D
heinz-oz
Post by heinz-oz »
The "Easy Pallette" in PI stores a lot of presets you can make yourself as smp files. Never looked at PictureShow but think I have a working one. Will check it out and let you know.
Greg Burson
Frames and Themes
Thanks I'll keep working with it ... I'll let you know what happens
