movie factory 4 problem codec
halbechtel
Post by halbechtel »
am trying to capture sat video using mf4 and hauppauge as the source. mpeg is the default format. when i start capture the following message apperas. mpeg capture does not accept HCW2 codec. select one from video format list. recommend YUV or RGB-24 codec. if i choose a format other than mpeg i get the following message. this format templet is not supported, it will use the default format. i cannot find a video format list that gives choices for various codecs. i am not sure how to proceed.
DVDDoug
Moderator
Post by DVDDoug »
My Hauppauge card is MPEG only. It has a hardware MPEG encoder, and it doesn't seem to work with any Ulead products.
This is not a problem. I use the Hauppauge software for capturing. Then I use other software (some of it Ulead) for video editing and DVD authoring.
